  New Posts New Posts RSS Feed - Wiper Nozzle Attaching 70 Torino
Danno View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Danno Quote  Post ReplyReply Direct Link To This Post Topic: Wiper Nozzle Attaching 70 Torino
    Posted: 18-November-2024 at 9:11AM
Help! Anyone have a good picture that shows how and where to attach the metal nozzle? It looks like there is one screw per nozzle, but it is not obvious to me where and how it attaches to hood. I have a set of nozzles off eBay, no screws, so if you know the screw thread size please tell me.
Danno
Post Options Post Options   Thanks (0) Thanks(0)   Quote handsofstone Quote  Post ReplyReply Direct Link To This Post Posted: 23-November-2024 at 12:37PM
Paging @Californiajohnny
Hinmaton View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hinmaton Quote  Post ReplyReply Direct Link To This Post Posted: 16-May-2025 at 10:42AM
I don’t “know” the answer, but I just put some squirters on mine (Amazon plastic jobbies), and spent a bunch of time trying to figure out the original routing but found almost nothing. There are two pressed bosses on the underside panel of the hood with two holes; I believe one is for the screw and one is for the small tang on the OEM nozzle. From what I can tell, the spray lines came to a T or F shaped 3/16” barbed adapter on the driver’s side and then ran into a hole above to a T and then through the under hood panel and out again to a similar hole on the passenger side.
I hope this helps some, good luck.
Hinmaton
This page was generated in 0.084 seconds.
